populate XML attributes issue
say, I have an XML file such as this one:
<?xml version="1.0"?>
<pdml version="0" creator="me">
<packet>
    <proto name = "geninfo" showname="General Info">
         <field name = "num" value="1" />
         <field name = "len" value="5" />
    </proto>
    <proto name = "data" showname="myData">
         <field name = "data" value="00:0A:0B:0C:0D:0F" />
    </proto>
</packet>
<packet>
         <field name = "num" value="2" />
         <field name = "len" value="4" />
    </proto>
         <field name = "data" value="EF:AA:FB:0C:0D" />
    </proto>
</packet>
As you can see, I have two packets.  I was able to get Labview to read in a child node array of two but now how do I read in the attribute as an array or collection of record for each "proto" and then obtain the data only.  For example, I would like to retrieve data from packet #2 and it should yield "EF:AA:FB:0C:0D", how do I do this?  I know how to retrieve a simple xml file but getting to the attribute part is a little tricky here.  Thanks
(3,153 Views)
Not sure exactly how you want to get to the data, but XPath makes it relatively straightforward, just use '@name' to specify an attribute.
Here you specify the packet number, you could drop the [number] and use Find All Matched Nodes to get an array for all packets as well.
(3,140 Views)
Where can I get that XPath VI, the one with the search icon?  Is this part of LV 8.6 also?
(3,133 Views)
Accepted by topic author lavalava
D'Oh!  That one is new for LV9.  Sorry.  Here is a variation using .NET (next you'll tell me you are on a Mac).
(3,119 Views)
