polymorphic output problem
I have a serie of polymorphic VIs, that leads to an output problems (broken arrow), see images.  I would like the case selector to handle 2 two types (purple and light blue) depending of if it is COM port or TCP/IP communication.
How can I do that? the select funtion isn't polymorphic enough ...
FB
Message 1 of 10
(6,237 Views)
Upload your actual VI(s), we cannot help by only looking at a screenshot...
Message 2 of 10
(6,217 Views)
here they are, the VIs
fb
Message 3 of 10
(6,198 Views)
Use a variant.
George Zou
Message 4 of 10
(6,182 Views)
Thanks Zou,
Thanks for the reply, have you an idea on how to do that?
Message 5 of 10
(6,160 Views)
http://www.ni.com/white-paper/4998/en/
You can use the Variant as input or output for your subVI. You just need to know what is the expected data type to make the conversion. In this way you can use (almost) any data type...
Message 6 of 10
(6,156 Views)
Accepted by oneFranck
George Zou
Message 7 of 10
(6,146 Views)
haha, now i got it 🙂
Message 8 of 10
(6,143 Views)
This could also be a good use case for OOP.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 10
(6,097 Views)
Or simply use VISA for both TCP/IP and COM.
Take a look this document:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3gXCAQ&l=en-US
George Zou
Message 10 of 10
(6,083 Views)
