plz need help
I want to make matrix or array 6*6 contain alaphapet letters and numbers that flashing randomly or if you can't may regular flashing
need help if you can plz reply quickly
thanks
(2,577 Views)
Make a 2-D array of strings.  I would color the background transparent.  That way you can overlay it on top of a 2-D array of booleans or color boxes.
Generate 2 random numbers from 0 to 5.  They would be your row and column indices.
Now set up a routine to change the color of that element in the 2-D array of color boxes (or true/false of that 2-D array of booleans) so that it appears like it is flashing for how long you need it to.
(2,561 Views)
