pluse trigger analog acqiure
dear all,
I want to use 100 pluses to trigger the analog channel and acquire 100 points voltage signal, the acquire sample clock refer by pluse frequency.
Can you give me some advices, thank you.
Eric
(2,337 Views)
Accepted by topic author EricYuanHongbo
I think this is useful:
https://www.ni.com/en/support/documentation/supplemental/21/ni-daqmx-data-acquisition-triggering-tec...
https://forums.ni.com/t5/LabVIEW/Finite-Retriggerable-Analog-Input-using-a-Counter-as-a-trigger/td-p...
and you can explore the many examples in LabVIEW from Help>> Find Examples>> Browse>> Hardware Input and Output >> DAQmx
(2,304 Views)
thank you for your support.
(2,293 Views)
