Online shopping is currently unavailable.
Please contact us for help or try again later.
plotting
I want the height info in z axis so that all three points can be plotted, and there will not be larger changes in coords as all points will be near to each other so there wont be a memory problem.
Message 11 of 20
(3,257 Views)
Memory use depends on the number of points, not on their relative distance.
Message 12 of 20
(3,253 Views)
There wont be many points sir there will only be max to max 3 points only
Message 13 of 20
(3,251 Views)
Sir, can you please help in telling that will stem plotting will help me in this case.
Message 14 of 20
(3,224 Views)
I am not familiar with the term "stem plotting". Please explain.
Message 15 of 20
(3,202 Views)
Sir this is the VI please have a look,
why the points aren't getting plotted, kindly please help.
Message 16 of 20
(3,185 Views)
Accepted by topic author Anjaney
Well, your string handling and array handling is all wrong.  You are only plotting 1 point, over and over and over again.
Get rid of the VISA stuff because it isn't doing anything and the Serial Configure does not belong in the while loop.  Also using Bytes at Port is wrong 99% of the time.
See attached modification.
Message 17 of 20
(3,167 Views)
Thank you @RavensFan for your support in helping me out am still learning lab view,
and sir can you please give me a hint on how to plot negative axis in the same graph.
Message 18 of 20
(3,149 Views)
If you only plot three points, you can use a FOR loop and process at the end. (top code)
If you want to continuously add more points as they arrive, a single shift register is all you need. (bottom code).
If new points arrive continuously, but you only want to show the last three points, initialize the shift register with a 3x3 array of NAN and replace the oldest row whenever a new point is received (not shown).
Message 19 of 20
(3,138 Views)
Thank you Dr. Altenbach for support, helps me alot. 😄
Message 20 of 20
(3,126 Views)
