plotting data with multiple y-axis using waveform chart
I am using LabVIEW 7.1 and am simply trying to split my data on one waveform chart using 2 Y axis.  One goes from 0-150 and the other from 800-1000.  I want them to graph on the same chart, and I have selected 'duplicate scale' when I right click on the chart, as instructed in the labview manual, but both of my data streams are still only connected to one of my axis.  I can't get it to recognize that one data stream should go on one axis and the other stream should go on the other axis.  Can someone help please?
(3,435 Views)
Right-click in the plot legend one plot. In the context menu select y-axis and after the axis you want for this plot. The scale is changed directly.
There is an image of the context menu attached.
I hope this helps
Greetings
shb
(3,421 Views)
Worked perfectly, thanks!
(3,408 Views)
