ploting x-y graph
hello,
               i am plotting using XY-Graph for x- axis displacement and y axis load. for every cycle i am bundle that array value and updating on x-y graph. but is shows at the end of point its comes to start line then plotting on the above same line, its happens for continuous cycle.
Example: i am using 2D array 1 column has a load value and column 2 has a displacement value.
please find an attachment.
Balaji DP
(2,684 Views)
OK... so what exactly are you asking? The XY Graph is plotting exactly what you are telling it to graph. Perhaps you need to sort the data before you plot it? Or perhaps, instead of using a line you want a scatter plot?
(2,670 Views)
