plot xy graph
Hi I am just making a simple simulation model in which a result of a formula is the acceleration.  This result I plot it against time.  By integrating the acceleration I obtain velocity and by integrating the velocity I obtain distance.  Those last results i plot them against time.  However, when I tried to plot distance vs. velocity, it looks like a get a graph of distance against time.  What would be the correct functions to be used to plot this correctly thanks.  The first picture attached shows a view of part of the model and the second pictures shows the results of the graph that I getting.  The graph that I need is taking correctly the y axis units but the x units are incorrect, it seems like it is just plotting against time.
Thank you
(2,960 Views)
Accepted by topic author fiatm
You can use a bundly function to plot to arrays into an xy graph. Check the attached VI for explanation.
Nitzz
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved;))
(2,958 Views)
Cheers
(2,923 Views)
