Plotting two graphs in one single graph
Hi.  This is my first time using control and simulation.  I want to plot two graphs within a single graph.  It seems that I have to use bundle and build arrays functions but I just do not know how to plot them.  The x points and y points of (2) are just defined by a single set of points included in the array defined.  The x points and y points of (1) are results of another formula, but both plots would fit in the same location of a single graph.  I hope my question is understandable.  I attach part of the model that I want to be plotted.
Thank you
(2,411 Views)
Accepted by topic author fiatm
You can try something like this. Check the attached VI.
Nitzz
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved;))
(2,408 Views)
(2,372 Views)
