plot with excel
i am plotting it in labview. but just in case if anyone else want to see the graph. i want to be able to export it.
to excel
Krispiekream
Message 11 of 14
(1,038 Views)
MY problem is not yet solved?
i can't use the property node.
my labview graph is in loose fit mode. NOT AUTOSCALE.
but my excel is in automode.
what can i do?
any suggestion guys?
Krispiekream
Message 12 of 14
(1,030 Views)
To access the excel graphs axis, if I remember correctly, you can obtain the axis collection from a chart property, and then via Item with the index (1 -> y, 2 -> x ???) get the axis you want. On that reference you can set the properties of the axis as you would do in excel.
If your issue is just about exporting the image, you can obtain the image of the graph by a method (invoke node) of the indicator and then save it as bmp or png.
Felix
Message 13 of 14
(1,021 Views)
Ah no wonder!
Little bit of a communication mishap there.  Thanks for clearing that up for me Dennis.
Message 14 of 14
(1,014 Views)
