plot two graphs in same XY graph
Hi
i want to save the graphs which are generated by a Vi into  a file programically
how this can be done
thanks in advance
augustin
Certified LabVIEW Developer
(4,020 Views)
Hi augustin,
you can use the "Write Waveforms to File.vi". If you have no waveforms, which format do you have?
Mike
(4,019 Views)
thanks for your reply .
I am saving it in .txt format
(4,016 Views)
Hi augustin,
you can use the write to spreadsheet file function. See the attached picture please.
Hope it helps.
Mike
(4,012 Views)
Accepted by mjaugustin
Hi Augustin,
       Get the array data form the XY graph using property node and convert that into spreadsheet string and then write in a text file.
       The attached image might be useful to you.
Raja
(3,999 Views)
Rajaa,
Obviously the XY graph has been constructed using X and Y data. It should be better (faster and memory saving) to use directly these data than to use a property node to retrieve them... 😉
Chilly Charly    (aka CC)
(3,988 Views)
