plot multiple.txt files
Hi guys,
I have quite easy question, however, due to my low experience, I am not able to solve it.
I have multiple .txt files which are consisting two columns each (temperature and intensity).
I would like to compare visually these files ( temperature vs intensity), means e.g. choose a number files (let say 7) and plot them.
I manage to do it for one single file (see below). How can I do this for multiple files?
All the graphs should be then in the same plot.
Thanks a lot,
Patrick
Message 1 of 8
(3,288 Views)
You just need to add a FOR loop over most of your code.
Message 2 of 8
(3,270 Views)
thanks a lot.
is it possible to assign parts of the path as a legend to the plot?
means e.g. C:/.../20200101.txt to have it as 2020101 in the legend of the plot?
Message 3 of 8
(3,247 Views)
Yes, Get File Extension will give you the stripped filename and with Property nodes you can index a plot and set its Legend.
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 8
(3,236 Views)
you mean something like this?
Unfortunately, it is not working. Where is my mistake?
Message 5 of 8
(3,193 Views)
Sorry, i missed there were updates in this thread.
You need to use Active Plot-property first, then you can set that ones Plot.Name. Repeat for every plot as needed. Thus it works better to do within the loop.
Qestit Systems
Message 6 of 8
(3,141 Views)
property nodes are executed from top to bottom, the active plot (ActPlot) must be the first entry in the property node
Spoiler
Message 7 of 8
(3,119 Views)
The code above in https://forums.ni.com/t5/LabVIEW/plot-multiple-txt-files/m-p/4241064#M1232806
works best for a freshly spawned XY Graph with out any data, and any plots.
Tinkering with the XY Graph can creat new plot id, especially increasing the "Plot Legend" via mouse drag.
when an implicit property is linked to an xy graph, both the xy graph and the property node will be deleted, if the xy graph is deleted.
therefore it can save sometime to use an explicit property node togeteher with a static reference.
A freshly spawned XY Graph appears to have no plot IDs, indexing a non-existing plot ID can throw a Warning (Error 1077 invalid property), but  can be ignored safely, as far as I have tested.
Spoiler
Message 8 of 8
(3,104 Views)
