Time Delay vs Wait
I have very basic question. What is the main difference between Wait(ms) and Time Delay.
I want to give a delay after executing some part of the vi as showned in the diagram. Whcih method is the best?
Message 1 of 23
(20,521 Views)
Hi Neevan,
both are (more or less) equivalent in your example.
The ExpressVI has the advantage of ready-to-use error in/out wires to force dataflow...
Message 2 of 23
(20,516 Views)
With the wait you can not reset this so you will always wait 100ms when you run it. The time delay allows you to reset it or not so you could have a one time or sometime wait and not others. THat is the biggest difference.
Tim
GHSP
Message 3 of 23
(20,509 Views)
To take the "mystery" out of Express VIs, remember that you can see what any Express VI does by right-clicking on it and selecting "Open Front Panel". This will create a new VI. Usually this is just a wrapper around another subVI which contains the bulk of the code for the Express VI.
Message 4 of 23
(20,498 Views)
Thank you... How to reset the Time Delay?
Message 5 of 23
(20,499 Views)
What do you mean by "rest the Time Delay"?  Do you mean change the amount of seconds it waits?  If so, you can wire a control to do it manually (although I don't see the benefit), or wire a double value from an algorithm which calculates the number of seconds to wait.
The value is wired to the "Delay Time (s)" input.
Message 6 of 23
(20,491 Views)
___________________________________________________________________________________________________________________________________________________________________
Tim
Johnson Controls
Holland Michigan
___________________________________________________________________________________________________________________________________________________________________----
Thanks for the reply, i know how to change the value for Time Dealy. I asked that question because Tim mentioned that it can be reset that is diffrence between Time Delay and Wait. So i want to know how to reset the Time Delay?
Message 7 of 23
(20,485 Views)
You might also want to read this.
Norbert
Norbert
Expert: Geometry
Message 8 of 23
(20,481 Views)
I guess you are confusing with the Elasped Timer which has the Reset option (I checked Time Delay it doesn't have one).
Message 9 of 23
(20,480 Views)
Norbert_B, In the link which you provided is very good one for me to learn. But it is not explaining me the difference between Time Delay and Wait
Message 10 of 23
(20,462 Views)
