plot multiple 3d
Can someone tell me how to  reshape 3 1D arrays to one 2D array that contains the z matrix for a3D plot?
Message 11 of 22
(5,615 Views)
Hi Ziedhosni,
What do those 1D arrays represent? The x, y, and z arrays? If those 3 1D arrays are just your x, y, and z values then you will just need to use the 3D curve.vi as suggested previously. If they are not can you clairfy what those arrays represent?
hfar2
Message 12 of 22
(5,565 Views)
I tried to use the 3D curve.vi as attached to this text. I can see the 5 concaces plots but unfortunately it is less beautiful and messier than the 3D mesh that requires the z matrix instead of the z vector.
My objective is to merge a coloured surface made of ( x,y,z) (varying from the blue to red according to the value of z) with a number of points in black that I can distinguish from the surface. Do you think it is posible to merge the mesh 3D with the 3D stem.vi for example?
Message 13 of 22
(5,539 Views)
And  what you want to get?
Surface or points on "column"?
You have 1000 points in arrays. Do you really think that you'll see anything on the "stem" plot?
Try "Basic Properties VI" for dots.
Or maybe you want enveloping surface for set of points?
Message 14 of 22
(5,515 Views)
I would like to get ideally a surface that is half transparant andthat is coloured from the blue to the red and in addition to the suface some points are marked on this surface or out side of it that can be bold and black to distinguish them from the surface.
You are right that the way of adding 1000 points will make the graph very complicated but unfortunately the mesh and the surface vi didn't work for me as they need those z matrix that I failed to generate from  3 arrays of 1D (x,y,z) that are not integers.
Zied
Message 15 of 22
(5,493 Views)
If you wish to get surface, you should understand it form.
And should have 2d array of points.
Instead of that you are trying to draw "heap" of points.
Do you have equation of surface?
Message 16 of 22
(5,485 Views)
Yes I have the equation. It is z=x^2+y^2
I would like to draw this surface and I would like to add some discrete points to the 3D space to see if they are included in the surface or far from it and how much far.
Zied
Message 17 of 22
(5,473 Views)
And what's the problem?
Message 18 of 22
(5,458 Views)
Здравствуйте)
Подскажите, как у вас получился такой график? Мне нужно совместить два 3D графика, в идеале на Stem 3D. С одним Stem все супер, но для совмещения все рекомендуют использовать set_plots.vi, но ссылка с Stem 3D туда не подходит. Я сделал совмещение графика с точками, но мне уж очень надо вид как на гистограмме.
Message 19 of 22
(5,329 Views)
Show your code and describe what you need
Message 20 of 22
(5,324 Views)
