plot graph in
Hi
I want to draw BER vs SNR ratio. I want to assume the signal power as one and we can change noise power in labview.
BR
uni
Message 1 of 11
(5,607 Views)
Hi
I want a graph like below in attachment. I have another question wich relates to USRP . for USRP we need to download some files , I can not remember the name but our teacher said that it is not working on 64 bit computer,
Can anyone help.
Message 2 of 11
(5,602 Views)
Hi pixel,
start like this:
You can refine the graph as you like…
Message 3 of 11
(5,596 Views)
Hi
Thanks , but can you send me the file, I do not know what is that does arrays. I am not the one who create that block. but I need 10 irratations with different BER and SNR values. How should i do that?
anyway, some one knows about USRP files? I can not open that block because of USRP file does not work on 64 bit computer.
Thank you in advance
uni
Message 4 of 11
(5,591 Views)
Hi pixel,
No, I didn't save it…
It's just 2 array constants, a Bundle node and a XY graph!
These are array constants…
You are the one who wants to create a plot, so you will be the one who has to program it…
When you need "iterations" you should use a loop. When you know the number of iterations in advance you should use a FOR loop…
Message 5 of 11
(5,581 Views)
I meant each time I want to add for example 3 db to SNR , so I should use add in for loop?
Message 6 of 11
(5,577 Views)
It's just two array constants, a bundle node and a XY graph!
I could find array constant but it is not like yours. also I could not find XY graph. there are icons like PLot Xy....but I could not find yours.
thank u
Message 7 of 11
(5,570 Views)
You must populate the empty array with the data type you want.  So drag a double precision number constant into the empty array constant.
The XY Graph is an indicator.  So look for it in the controls palette on the front panel.  There is an entire subpalette just for graphs and charts.
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
Message 8 of 11
(5,561 Views)
Hi
this is an error.
I want to set for example 20 iritations and then see the graph. but there is an error , How ever I do not know this structure works.
Message 9 of 11
(5,548 Views)
Gerdw Or Cruz you do not know what shoudl I do? any nights?
Message 10 of 11
(5,534 Views)
