plot array 2D and 1D in the same graph
I am working with an optical fiber transducer. The driver for Laview, I'm using, I get the values ​​in 2D array, where rows are the channels and the columns of the sensors. The driver for Laview, I'm using, I get the values ​​in 2D array, where rows are the channels and the columns of the sensors. I need to plot on the same graph, each of the separate channels and all channels simultaneously.Attachment file with the code.
(2,336 Views)
Is this related to your other question? Should the two questions be merged?
(2,333 Views)
If this relationship, the two questions refer to the same vi
(2,331 Views)
