please help! How to add FTDI 2xx in labview project. Thanks Re: Labview with FTDI D2XX drivers
I try add DLL in Labview project.
but it seem still have problem
can anyone let me know if DLL install correct?
 How to fix the project build problem?
 see 3 attached files.
(4,410 Views)
Accepted by topic author zy6
Hey zy6,
I was able to find a couple of articles from LTDI with some examples and instructions on using the dll. You can find them here:
http://www.ftdichip.com/Support/SoftwareExamples/CodeExamples/LabVIEW.htm
http://www.ftdichip.com/Drivers/D2XX.htm
There is also a long article with a similar question that I found here:
https://forums.ni.com/t5/LabVIEW/Labview-with-FTDI-D2XX-drivers/td-p/94458
Hopefully one these links can help you to move forward with your code!
VanCamp
(4,360 Views)
