pid without toolkit
Hi!
I need to implement a temperature control by changing the voltage of a power supply connected to a heater.
I don't have PID toolkit, but I know how PID theorically works.
Attached: VIs (Untitled 1 the principal one)
Any suggestion, help or hints are appreciated.
Thank you
Message 1 of 14
(13,332 Views)
Message 2 of 14
(13,329 Views)
Accepted by ufo900
Hi ufo,
see here for the "Simple PID" example that NI once used to ship with LabVIEW...
Message 3 of 14
(13,320 Views)
well thank you 🙂
i'm almost new programming labview.
Any suggestion how to implement all that into the program attached?
Really thank you
Message 4 of 14
(13,316 Views)
Hi ufo,
the SimplePID is as simple to use as its name implies: all it needs are PID parameters and the current value of the process variable and it will output the set value...
There's an example in the mentioned ZIP file included!
Message 5 of 14
(13,310 Views)
well ok, but i don't understand one thing:
i have to set temperature by a determined wave/value, but i need to control the voltage to do that.
how to solve? I mean.. the setpoint is temperature, process value is temperature, but the output of the pid how can it be relationed to the voltage?
Thank you
Message 6 of 14
(13,305 Views)
Hi ufo,
"the setpoint is temperature, process value is temperature, but the output of the pid how can it be relationed to the voltage?"
The output of the PID can be seen as unitless value. You just convert it to your needed output value. To do so you have two options:
- set the PID parameters so it will scale the output to the needed range
- use "unitless" PID values to get an unitless output from SimplePID and scale that value to your needed range
For understanding PID it may help to read the manual of any industrial ready-to-use PID temperature controller. Wikipedia might be a good source of information too...
Message 7 of 14
(13,302 Views)
I think I did it but i can't understand another thing:
voltage didn't read the voltage.. the output value fo the pid is added to the current voltage so i can module the difference between the desired temperature and the measured temperature.
Voltage is read in another VI (simpler, just to control if every instrument is working) but when I insert the pid, voltage isn't read anymore.
Do i have to insert a sequence? Don't know what to do 😞 Smiley Frustrated
Message 8 of 14
(13,290 Views)
Hi ufo,
did you ever think about the DATAFLOW? It's the basic principle of LabVIEW...
You created a loop that seems to run the PID vi ("seems" as I miss a lot of subVIs). This loop will stop on error or user input. After that loop has run you call a second loop with your voltage measurement. There's a data dependency! THINK DATAFLOW!
You would have seen this be some elementary debugging. Did you even try this?
Message 9 of 14
(13,279 Views)
While I was waiting you answer I already solved the problem.
Really thank you 🙂
Message 10 of 14
(13,275 Views)
