pid autotune for temerature control VI to c code convert
I am using labview 2013 and 2013 c code generator.
Goal is to convert autotune PID code to c code so that I can use in microcontroller/ARM based.
I have tried using several online library in c like on github, but none are working perfectly otherwise.
In labview, found PID autotune for temperature. But I saw lots of input/output paramters in it.
In my MCU system I have :
1. Temperature reading every one sec(input)
2. Time of reading : every one sec (input)
3. Desired temperature is user filled (input)
Output needed are:
1. Autotune PID values calculated
2. Output range 0 to 100% which will be converted to PWm then.
How to set rest/remove rest of input/outout values in labview temperature VI?
Message 1 of 1
(1,988 Views)
