picture control rotation - losing color table
Hi:
I have some code to rotate pixmaps in a picture control.  I am attaching it here with a sample .png.  I lose the default color table when the rotation occurs, and I don't know why.  Any thoughts?
Don
(2,719 Views)
You probably need to manually select the polymorphic instance for the "draw unflattened pixmap.vi" in the orientation event case. Right-click on it and "Select type... Draw 8 bit pixmap". Seems to work just fine here after that. 🙂
(2,692 Views)
Don't think I would have figured that one out (and I've been doing this for a long time).  Yes, it works fine now.   I guess this means we can't count on the 'automatic' select type.
I knew I should have stuck with the intensity graph!
Thanks again....Don
(2,686 Views)
