Try using Device 0, this is the default device, your sound card. Devices, in this case, are the sound card. Unless you have more than one sound card (and I don't know how to determine which is 0 and which is 1 in that case) you should use Device 0. Lines on the sound card are determined by the drivers. All you do is play or record.
