physical channel delete from labview
Hi ,,,i have one doubt,,consider i have Two  Daqmx Channel Selection list controller for only one daq in Frontpanel,suppose i select AI0 for one measurement from one controller .then how to remove the AI1 in the Second Daqmx selection list controller in the fronpanel by using programaticcaly..
is anybody tell help to me
(2,708 Views)
Hi
Can you give an image of your Front panel? I assume you are using a DAQmx vi with physical channel selection input control terminal on the Front Panel.
I would like to know why you have two controls on the FP for a single DAQ vi.
Regards
Freelance_LV
TestAutomation Consultant
(2,702 Views)
Thanks for Replay
i have two channel selection control for one analog daq...suppose if i select ai0 fotr temperature ,that channel should not be showed on ther control(for pressure)...its like enum....in enum i know how to delete item from list...but channel selection control....i didnt get it...pls see the image
(2,683 Views)
Hi
I have not had such a requirement before, as I had mostly used combo boxes, tables or trees for channel configuration settings.
In your case, I can suggest something as in the attached image.
Hope it meets your requirement. I would like to know if there is any other simpler or better method to achieve this.
Regards
Freelance_LV
(2,673 Views)
