php + mysql + labview web server
Have you tried php acting as cgi handler?
Its not the best, but may work.
Another thing: Embedthis have his own php sourcecode to compile on http://github.com/embedthis/packages.
Can you post the .conf file?
Message 11 of 16
(1,976 Views)
This is the code.
Best regards.
Message 12 of 16
(1,971 Views)
Hi again,
In the site of Embedthis has a version of AppWeb to Download (http://embedthis.com/software/appweb-4.2.0-0-ms-windows-x86.exe.zip)
I think you can find the correct dlls inside it. (php dlls) and an example of conf file with php enabled.
Try adding a new virtual host pointing to a diferent folder.
Message 13 of 16
(1,944 Views)
hello,
Thank you for your link, I think it is a PATH problem.
Best regards.
Message 14 of 16
(1,923 Views)
I saw again the configuration and it did not seem to work .. someone to perform the procedure so clear and precise .. I take.
Maybe a problem typing or omission .. or a bad PATH .. If someone happens to use the PHP module .. it could manifest itself ..
Is it sure that it works?
Best regards.
Message 15 of 16
(1,858 Views)
Did you find the solution? This would open the door to a lot of things ..
Best regards.
Message 16 of 16
(1,753 Views)
