02-12-2013 04:33 AM
Have you tried php acting as cgi handler?
Its not the best, but may work.
Another thing: Embedthis have his own php sourcecode to compile on http://github.com/embedthis/packages.
Can you post the .conf file?
02-12-2013 06:04 AM
This is the code.
Best regards.
02-16-2013 12:10 PM
Hi again,
In the site of Embedthis has a version of AppWeb to Download (http://embedthis.com/software/appweb-4.2.0-0-ms-windows-x86.exe.zip)
I think you can find the correct dlls inside it. (php dlls) and an example of conf file with php enabled.
Try adding a new virtual host pointing to a diferent folder.
02-18-2013 07:38 AM - last edited on 02-18-2013 09:45 AM by JordanG
hello,
Thank you for your link, I think it is a PATH problem.
Best regards.
04-02-2013 05:35 AM - edited 04-02-2013 05:38 AM
I saw again the configuration and it did not seem to work .. someone to perform the procedure so clear and precise .. I take.
Maybe a problem typing or omission .. or a bad PATH .. If someone happens to use the PHP module .. it could manifest itself ..
Is it sure that it works?
Best regards.
01-10-2014 11:12 AM - edited 01-10-2014 11:13 AM
Did you find the solution? This would open the door to a lot of things ..
Best regards.
