01-18-2014 04:13 AM
How could I get two signal with different phase angle from same signal simulator ?
01-18-2014 05:08 AM
What is a signal simulator?
01-19-2014 05:47 AM
I'm referring to simulate signal function used as block diagram window in labVIEW.
01-19-2014 06:49 AM
You can e.g. use the Sine Waveform.vi under Signal Processíng -> Waveform Generation. It allows to enter a phase.
Cheers
Edgar
01-19-2014 07:43 AM
The Simulate Signal Express VI also has a phase input (it uses Sine Waveform VI internally).
Rahulro if you need two signals with different phases then you just put two Simulate Signal express VIs and wire different phase values to them.
Cheers,
J.
01-19-2014 10:43 AM
Jarek, I did the same but I was just thinking of using only one Simulate Signal express VIs.
