performance and memory usage memory attributes
I am using performance and memory usage to check the amount of memory used by the VI. It has avg, min and max memory used by the vi.
I need to know the amount of memory still hold up by the vi, which is still not released by it.
Is it possible to get that parameter?
Thanks!
(2,464 Views)
Hello LVCoder,
Check KB How Can I Monitor a VIs Memory Usage? It gives three options to check the memory usage of your VI; you could use the second one which is done programmatically using a VI Server Reference and a Metrics Property Node. It allows you to see the size in bytes of the block diagram, front panel and code.
Best Regards,
Alina M
Applications Engineering
(2,436 Views)
