pen-up pen-down on etch-a-sketch
I have a 6th grade class that has made a simple etch-a-sketch using ex xy graph. The students want to be able to move to a new location without there being a trace. Similar to the pen-up pen-down question. They also have this working reading analog voltage inputs from a joystick. Any suggestion would be appreciated.
Vaki
(3,324 Views)
Accepted by ptampas
I would probably suggest using a picture control for something like this, not an XY graph, but since you already have it, you can do a "pen up" by plotting a point where either value is NaN. The point will not appear on the graph.
Also, I believe there should already be at least one etch-a-sketch example online. If you find it and look through it, you might get additional ideas.
___________________
Try to take over the world!
(3,300 Views)
Then again, there is no "pen up" on an etch-a-sketch"!  Great, introducing LabVIEW to sixth graders! We'll have some really experienced LabVIEWers when they get out of college!
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,281 Views)
So much for job security.
(3,271 Views)
The NaN with selectors worked just fine. I was using a Vernier Sensor DAQ to read analog voltages from a joystick. Placed a PenUp PenDown on the front panel and the kids thought it was great.
 Thanks to all for the suggestions.
Vaki
(3,251 Views)
