01-28-2008 02:03 PM
01-29-2008 01:44 PM
Hi Ronster,
Are you using the Power Spectrum vi located in the Frequency-Domain section of the LabVIEW function palette? Have you verified that the actual values being sent to the peak detector disagree with the outcome you are getting? It might be useful to create an indicator before the peak detector in order to have values to compare against.
The peak detector has a location, amplitude, and second derivative output. Which one are you reading?
Lauren
01-29-2008 02:08 PM
01-30-2008 12:28 PM
01-30-2008 12:39 PM
I copied the 'guts' of the peak search vi and then pasted into my data recall vi. I wanted to keep the 'red' threshold cursor. That works fine! It's just the frequency values. The peak values are right on.
Ron
01-31-2008 04:29 PM
Hi Ron,
From the example I am looking at, I do not see any functions that read the frequency. The peak detector itself only outputs the location, amplitude, and second derivative.
How are you acquiring the data and how are you reading the frequency?
Lauren
02-05-2008 06:53 AM
The data I am looking at is a saved file with six fft spectra, so the frequency data and amplitude data already exists. I am just pulling it back out and want the peak search to do it's thing.
02-05-2008 08:21 AM
02-06-2008 07:17 PM
Hi Ron,
So if I am understanding you correctly, you are reading the frequency as the location of the peak amplitude. Are you only receiving one value that is much larger than the expected value? Have you tried taking a look at the graph itself prior to sending the data into the peak detector to see where the faulty data may be coming from?
It may be worth posting the data you are working with so I can try playing around with the Peak Detector vi and see if I can reproduce your issue.
Lauren
02-06-2008 07:21 PM
Hi Labjaho,
For better support of your issue, you should probably try posting on the French forums.
Lauren
