peak detection with two thresholds
David, please save the vi in version 8.6.
Message 11 of 20
(3,628 Views)
Accepted by topic author Current_93
Message 12 of 20
(3,622 Views)
Dear David,
Can you advise me how to do the same but with C:\Program Files\National Instruments\LabVIEW 8.6\vi.lib\Analysis\8numeric.llb\Threshold Peak Detector.vi
This  "Threshold Peak Detector.vi" is more simpler than others and thus it works faster. In my task "faster" is very needed.
Please, advise me.
Message 13 of 20
(3,583 Views)
Sorry, I am on vacation at the moment and not near a pc with labview.
I am sure somebody else will jump in to help.
Cheers
David
Message 14 of 20
(3,579 Views)
Current 93 wrote:
Dear David,
Please, advise me.
Threshold Peak Detector.vi and Peak Detector.vi that David used have different functionality.  It may work faster, I'm not sure, but it works different too, make sure it is what you want.
Tim Elsey
Certified LabVIEW Architect
Message 15 of 20
(3,567 Views)
Notice Threshold Peak detector only detects peaks that go above and then below the threshold line.  Peak Detector finds all local maxima.  Also, the information returned by Threshold Peak Detector isn't as nice (as you can see by the red dots not being right on the peak but on one of the slopes going to the peak.  This obviously can be remedied, but I didn't do it here.  See here and here if you go down that road.)
Tim Elsey
Message 16 of 20
(3,562 Views)
Dear Tim!  Thank you very much for your support, but for my task and for my input signal is approaches threshold peak detector.  For my 3M input record it is faster than other peak detectors.
Message 17 of 20
(3,548 Views)
Well, here's David's vi with Threshold instead.  It doesn't work quite the same because of the issue I mentioned in my last post with the found peak not exactly lying on the real peak.
Tim Elsey
Message 18 of 20
(3,541 Views)
How do you create two threshold, and calaulate the number of peaks both positive and negative peaks outside of the two threshold. the reason is because i want to get peaks from both ngeative and positive from the 2 threshold values. Hope that u could give me some examples on how to build it?
Message 19 of 20
(2,633 Views)
Hello fops!
The Peak Detector.VI can be used to identify peaks as well as valleys that fall above or below a specified threshold. I’d suggest thoroughly looking through the above posts and referencing the context help for the Peak Detector VI.  If afterwards you still have unanswered questions, I’d recommend starting a new thread. This thread is almost five years old and is less likely to be viewed by the NI community members. Starting your own thread will provide you with quicker responses to your questions from members.
Message 20 of 20
(2,593 Views)
