DSP memory read error.
Hi everyone. i have a question regarding the dsk c6713. i try to create a program in labview 8.6 with dsp module, but when i try to run, an error message appears as
"DSP memory read error. The target hardware is no longer responding. Please verify that the hardware is functioning properly and retry the VI.  Select an item from the list to see its errors. Double-click the error, or click the Show Error button, to highlight the object causing the error. You must click the Close button in this window before you can click the Run button on the VI again".
I have searched on the internet regarding the problem, but it seems cant solve my problem. FYI, im not installing the dsk c6713 driver yet because my lecturer misplaced the cd driver + no driver can be found online. Can anyone suggest any solutions? Thank you in advance.
(3,587 Views)
I have the same problem.
"DSP memory read error. The target hardware is no longer responding. Please verify that the hardware is functioning properly and retry the VI."
(3,330 Views)
