path array
The problem I'm having is with array of paths. I include a zipped folder with some directories and a vi I use to retrieve information from the folders. The vi keeps returning two cells with empty path without any reason that I can think of. I have tried several solution but non of them work yet. The problem is affecting other section of my project.
Please any idea on what's causing this problem?
(3,534 Views)
(3,526 Views)
Hi
Are you talking about the image attached ?
Regards
Paul
(3,520 Views)
Yes. I expect to see not a path instead of a blank.
(3,513 Views)
Accepted by topic author aderogba
Hi
See the attached solution, you had a shift register missing in the inner loop, therefore all the not a paths you were inserting were not being passed around, only the last not a path on each row would be seen.
Regards
Paul Rawlinson
TBG Solutions
UK
(3,495 Views)
