path array
The problem I'm having is with array of paths. I include a zipped folder with some directories and a vi I use to retrieve information from the folders. The vi keeps returning two cells with empty path without any reason that I can think of. I have tried several solution but non of them work yet. The problem is affecting other section of my project.
Please any idea on what's causing this problem?
(3,733 Views)
(3,725 Views)
Hi
Are you talking about the image attached ?
Paul
(3,719 Views)
Yes. I expect to see not a path instead of a blank.
(3,712 Views)
Accepted by aderogba
Hi
See the attached solution, you had a shift register missing in the inner loop, therefore all the not a paths you were inserting were not being passed around, only the last not a path on each row would be seen.
Paul Rawlinson
TBG Solutions
UK
(3,694 Views)
