passing parameters betweeen LV versions
Does anyone know how to pass parameters between LV versions? For a reason too complicated to get into, I have to run one program in LV 2009 (32-bit) and the other in LV 2009 (64-bit). Is there any way to pass parameters (strings, etc.) between the two programs? The only thing I can think of is turning the programs into executables. Any other ideas? Thanks in advance for any help you can give me.
Message 1 of 9
(3,587 Views)
Hi Dan,
how will making executables help to pass parameters between VIs? Shouldn't you be using something like files to pass them?
Message 2 of 9
(3,573 Views)
Hi DanX!
Are the two programs supposed to run on the same machine? (if yes, at least one of them has to be an executable, since, as far as I know, you can't run two version of Labview at the same time)
In any case, data can be exchanged between them via Datasocket, TCP/IP, UDP, Shared Variables, files....
Marco
Message 3 of 9
(3,562 Views)
Hi Marco,
I often run two (or even more) LV versions at the same time - it works, but you have to be careful Smiley Wink
Message 4 of 9
(3,558 Views)
You can run two different versions of LV on a single computer at the same time.
I can talk directly within one version of LV between programs using "open vi reference" and "invoke node" to get and set parameters, controls, etc. I need to do this between two versions of LV. I thought of a way to do this indirectly by reading/writing from text files, etc. but I was wondering if there was a direct way. Doing this with executables may amount to the same thing. But I was fishing for a better method (i.e., more direct passing)...
Message 5 of 9
(3,543 Views)
Datasocket, TCP/IP, UDP or Shared Variables aren't ok?
Moreover they are faster then using files...
Message 6 of 9
(3,534 Views)
I have to side with Marco on this suggestion.
Ben
Message 7 of 9
(3,525 Views)
I only have limited experience with shared variables, datasockets, etc. I knew there was probably an easy solution. I will check it out the examples. Thanks.
Message 8 of 9
(3,516 Views)
Network shared variables would probably be the easiest way to go, followed by datasockets.  However, neither offer a good way to synchronize the data, so you can create race conditions if you are not very careful.  It this is a problem, use TCP/IP.  For raw speed, UDP is probably your best bet, and can be made synchronous.  All are network protocols, so will work on multiple machines as well as a single machine.
Message 9 of 9
(3,495 Views)
