pass on arrays from cRio
can I pass on arrays as network/shared variables?
I get errors 1950678941 and 1950678965
Read variable with timeout and cannot be converted to data type of this shared variable node.
Should I better define the array as user value, then I guess I have to define the correct size? as in 100 or so values?
its cRio in hybrid mode.
(3,169 Views)
it seems it has more to do with some typedefs. Some data is bundled into clusters and they have typedefs to them. So I added something to one typedef and this is what is playing up. Undoing all this, then populate the array with the vi running on the cRio. Then I can read that array back on the host PC no problems.
(3,146 Views)
@Steffen01
So... If I understand you correctly, you are no longer having trouble with this?
(3,100 Views)
the arryas are passed on, the problem seems to be somewhere else.
(3,092 Views)
