XY Graph Multi Plot - Data does not Match Graph
I am trying show two plots on an XY Graph and the data I feed into the graph does not match what the graph shows me. When I right click the graph and export the data to excel the numbers are correct but the image seems wrong because the points do not align with the X values.
X1 Y1 X2 Y2
2017-12-21 85 2017-12-21 54.4156
2017-12-22 85 2017-12-22 47.3879
2017-12-27 85 2017-12-27 54.6753
Why would my X values on the graph be shifted?
(4,391 Views)
These are dates, so what is your timezone? Can you show us your code?
(4,390 Views)
I have attached a picture of the code I am using. I am reading data from a database and the cut off wires are just a query.
My timezone is US Pacific.
(4,384 Views)
If you scan a time, it assumes GMT. If you want to graph relative to your timezone, you need to adjust accordingly.
(4,352 Views)
Accepted by topic author JohnSutton
I solved the problem. I was trying to graph just with date and I had time unused selected on the graph but LabVIEW didn't like that and set all the time stamps to 4PM for some reason. I added a segment that sets all the times to midnight before they get to the graph so the data shows up above the correct date.
(4,334 Views)
