pass dimension size of array handle to DLL
what is the correct way of passing Array handle dimensions, I found this document, that only describes the memory situation and some examples that suggest both following possibilities:
typedef struct {
        dimSizes[dimensions]
	ArrDatatype data[1];
} Array **ArrayHdl;
 or this one:
typedef struct {
	int32 dimSize1;
        int32 dimSizeX;
} Array **ArrayHdl;
(3,140 Views)
Accepted by Bublina
typedef struct {
} Array **ArrayHdl;
 or this one:
typedef struct {
	int32 dimSize1;
        int32 dimSizeX;
} Array **ArrayHdl;
They are equivalent, except that the int32 has been forgotten in the first one!
And a comma in the type declaration for both!
Personally I tend to use the second one, but never did more than 2D arrays. For multi-D arrays, the first may be interesting if you happen to loop through the array dimensions somehow.
Rolf Kalbermatter  My Blog
(3,105 Views)
Hi Bublina,
as rolfk
(3,087 Views)
Ok, thanks for reply. I use the second one, it makes the code more readable.
(3,066 Views)
