parallel while loop
When there are no structures surrounding that particular section of code, there is nothing to stop it from running during all the loop iterations. A picture of it is included in my first message.
Message 11 of 25
(2,291 Views)
When there are no structures surrounding that particular section of code, there is nothing to stop it from running during all the loop iterations. My intention is to shut off that section of code when the user types "Hello". A picture of the program is included in my first message.
Message 12 of 25
(2,286 Views)
"When there are no structures surrounding that particular section of code, there is nothing to stop it from running during all the loop iterations."
This is when you use a case structure.
This is also why you have been asked to work through the tutorials.
Lynn
Message 13 of 25
(2,278 Views)
What do you what to happen when?
Tell us in details what the code should do, and in what order, and what deside the order.
I can figure out what part of the code you are refering to?
If you only what to run certain part of a code, then you should use the case structure.
Or better at state mashine is what you need.
Message 14 of 25
(2,276 Views)
I know the function of a case structure, and it dosn't the section of code it is surrounding for all while loop iterations. When a differing signal comes in it will change its case. When the user types "Hello", I want it to respond by shutting off that case for the entire run.
Message 15 of 25
(2,260 Views)
That is why I didn't use a case structure.
Message 16 of 25
(2,258 Views)
I know the function of a case structure, and it dosn't shut off the section of code it is surrounding for all while loop iterations.
Message 17 of 25
(2,253 Views)
That is exactly what a case structure is for.
Most likely you have wired the selector terminal to the wrong signal.
Please post your VI.
Lynn
Message 18 of 25
(2,242 Views)
A case structure does what you tell it to do, nothing more, nothing less.
You need to give more details of what you want.
What code do you need to have executed only at a certain condition and what is the condition?
Message 19 of 25
(2,237 Views)
Message 20 of 25
(2,234 Views)
