parallel while loop
I'm having trouble with executing a secondary while loop. I'm trying to shut off a portion of my block diagram for the entirety of the run based on the input from an external wire. I would really appreciate help on this, thanks.
Message 1 of 25
(5,742 Views)
You do not have parallel loops. Because the wire comes out of one loop and enters the other, the loops will execute sequentially.  This is fundamental to the dataflow paradigm of LabVIEW.
It looks like you may be new to LabVIEW. If so, please start with the free on-line tutorials. They should cover some of these basic concepts
Lynn
Message 2 of 25
(5,721 Views)
Thanks for the correction. How can I, for the extent of the run shut off that particular section of the block diagram from the true or false input though.
Message 3 of 25
(5,696 Views)
Please take some of those tutorials.
Why have an external loop? Why not have everything inside the main? Why all those comparisons to string values? You can wire a string directly to a case statement.
Message 4 of 25
(5,686 Views)
I'm not seeing a reason for the second loop.  Why can't you just put that logic in the main loop you already have, including the writing of the string indicator?
Message 5 of 25
(5,684 Views)
Unfortunately, when I put the while loop inside the main, the entire program stops functioning as it was intended, I have researched the functions of all the structures and none seem to shut off that portion of the block diagram for all the while loop iterations in the run.
Message 6 of 25
(5,627 Views)
You don't understand. Do NOT place the second while loop inside the main. Place just the code inside the while loop in your main.
Message 7 of 25
(5,620 Views)
How do I go about shutting that section off for the extent of the loop iterations when there is an input though.
Message 8 of 25
(5,614 Views)
I've tried that, but it dosnt perform the function I want it to.
Message 9 of 25
(5,606 Views)
Then show us what you have and tell us how it isn't doing what you want.
Message 10 of 25
(5,569 Views)
