06-08-2011 11:53 AM
I am trying to control a stepper motor using two pins of a parallel port. Unfortunately I cant write directly to the parallel port register because I am using a USB-to-parallel driver. I am trying to use visa but I am having so many problems as follows:1) when I write a byte to the pins and then write a different byte, only the first byte remains and the new bytes aren't written. 2) sometimes I have errors like timeout or visa session open while its actually closed. At first I tried shorting pins 11 and 12 as it said in (http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB) and then I tried shorting pins 1 - 13, 10 - 16, 11 - 17, and 12 - 20 as recommended by a discussion here and I am still facing a problem of only the first byte written and can't be changed, Whats the best way to do this?? I am using simple Write-visa, Close-Visa command subsequently
06-09-2011 12:24 PM
Hello aabba002
Thank you very much for choosing National Instruments! Can you please provide me with the model number of your motor, which version of LabVIEW you are using and which operating system you are running LabVIEW in? Can you please either take screenshots of the errors you are receiving and post them or take notes of error codes reply with them? That will be helpful to me to address your individual issues. I understand you are using a USB to parallel port adapter but can you tell me if any of the following documentation is useful to you? (Just for my interest, can you please provide the model number of the USB-to-Parallel port adapter?) Is there another PC with a parallel port that you could test your code on?
How Do I Use the Parallel Port in LabVIEW?
Configuring Serial and Parallel Ports with VISA
http://zone.ni.com/reference/en-XX/help/371361G-01/lvinstio/visa_serial_parallel_ports/
Setting Individual Bits for the Parallel Data Port Using LabVIEW
http://digital.ni.com/public.nsf/allkb/C80752C53094C296862565F3007AC765
There appears to be developer zone where someone has controlled a stepper motor with the parallel port but a user has stated they are having issues using a USB-to-Parallel port adapter.
Stepper Motor Control (Parallel Port)
http://zone.ni.com/devzone/cda/epd/p/id/3611
Please keep me in the loop!
03-26-2012 03:19 AM
Hi aabba002,
Did you manage to controle you motor via your serial port?
i am trying to do the same but ... i can't even start .... without the servo and the motion controler it seems sooo complicate .. but sheaper for me 🙂
please, let me know is there in any new
thanks
amayas
03-27-2012 12:31 PM
Hi amayas,
What problems in particular are you experiencing? Were you able to take a look at some of the documentation posted by Greg S.? Let me know some specifics of the errors you're facing and hopefully I'll be able to offer some guidance.
Best,
03-28-2012 04:49 PM
Dear Courtney,
thank you for your answer.
my first problem (i have several for now !!!) is how to get the addressof my RS223 port to be able to contact with him.
I am using a USBto RS232 converter (my RS 232 has 9 pins) and it is an U232-P9 addaptor.
please, can you help?
thank you
amayas
03-28-2012 06:01 PM
When you plug the adapter in, a new com port will show up in windows device manager and in MAX (Measurement and Automation Explorer), unplug it, the port will disappear. Just take note of this port. The VISA Resource Name that you have for any serial port communication has a pulldown menu when you click on the arrow on it's right side. You select the port from the list.
03-29-2012 05:07 PM
Hi Dennis_Knutson
wonderful answer !
igot the com address of my RS232 ! perfect !!!!!
now, i have an other question ...
the RS232 sends only high / low wignal (digital signal)
but, i have to send an anlog courant to make the motor turne,
does this mean that i have any way to use an amplifier to make my motor turne?
thank you, all
amayas
03-29-2012 05:11 PM
This is what happens when you post the same question in multiple threads and when you don't start a new one.
See the other one you started.
