10-09-2006 08:21 PM
10-10-2006 11:56 AM
02-01-2008 03:35 PM
02-04-2008 01:51 PM
Hi Yi,
There are a lot of things that you can do to optimize the memory use in the LabVIEW VI. Take a look at that knowledge-base article and also the LabVIEW help for VI Memory Usage to see where you can make improvements. It lists several factors that can affect VI performance and offers techniques to help you obtain the best performance possible. As far as any restrictions, the best place to check is the LabVIEW Interface Simulation Toolkit readme files. I have not noticed anything that could be the cause of the problem you are having. Also, it might help if you post a simplified version of your code or a screenshot of it so that we can see if there is anything obvious that could be the cause.
Carla
02-05-2008 02:47 PM
02-06-2008 01:23 PM
Hi Yi,
Thanks for the information. I am not sure why you are seeing a different amount of memory usage in the task manager than in the profile performance and memory window. What version of LabVIEW are you using? There has been some noted trouble with memory leaks in LabVIEW 8.2 with mathscript. If you are using this version of LabVIEW, we could try using the trial evaluation version 8.5 with the code and see if that solves the problem. Could you possibly post a screenshot of the block diagram and of the profile performance and memory window and the task manager? It might help determine what is going on.
Carla
