open text file
i still cant find a solution plz help
Message 11 of 19
(2,412 Views)
ok so this file has to open in notepad absolutly??
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 12 of 19
(2,408 Views)
here is a link that may help:
http://forums.ni.com/ni/attachments/ni/170/133063/1/Unbenannt.PNG
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 13 of 19
(2,405 Views)
here is the vi and it should be the answer you where looking for:)
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 14 of 19
(2,400 Views)
can i get a 8.0 labview example..plz thk u
Message 15 of 19
(2,385 Views)
Accepted by jeyanthi
sure here it is:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 16 of 19
(2,383 Views)
thk u..its helps
Message 17 of 19
(2,369 Views)
Here is a quick example for double clicking on the listbox and having it open the file
Message Edited by for(imstuck) on 05-25-2009 11:40 AM
Message 18 of 19
(2,349 Views)
I noticed, the only thing really needed in the while loop is the event structure, unless you will be changing the contents of the directory while the program is running. Otherwise, you don't need the while loop populating the list box and it can be placed outside the loop.
Message 19 of 19
(2,330 Views)
