open file with reference
Hi
I want to open files with a reference in hidden mode. Is this possible?
Because I want to make a program where the user can choose a new test station and then the controls and indicators will be created (or become visible) and the subroutine begins to run.
Does anybody have a good idea or even an example how to do this?
Yves
Message 1 of 17
(3,935 Views)
Hi Yves,
what does "hidden mode" mean? Do you want to open a text (or binary) file?
Greets, Dave
Message 2 of 17
(3,928 Views)
@ daveTW
No, I want to open the subvi in background without seen it. In this subvi runs a continuous task which can be stopped.
Message 3 of 17
(3,921 Views)
Hi Yves,
You could control your Test- VI with a global variable as shown below. This solution uses two independent while- loops. The Test-VI won't be opened and does the work invisible.
This is the Main-VI
And this is the Test-VI
Greets, Dave
Message Edited by daveTW on 09-28-2006 03:30 PM
Greets, Dave
Message 4 of 17
(3,915 Views)
Hi Dave
Thanks for your answer. Well, the problem lays a bit deeper:
This is a solution I'm already using. But know I have to adapt the program for several stations. (60 or more)
And I think there must be a better solution than having 60 subvi's (or loop) in the main loop.
That's why I started to think about instances and references... BUT I actually don't have any experience with this and I would appreciate any help and hint.
Yves
Message 5 of 17
(3,909 Views)
You can use VI Server to run a VI. The attached picture is a simple example. There are numerous properties and methods available in LabVIEW. The shipping examples show some of the others and there have been a lot posted to this forum as well.
Message Edited by Dennis Knutson on 09-28-2006 09:14 AM
Message 6 of 17
(3,900 Views)
@ Dennis:
Do I have to use 60 loops if I want to start 60 different programs? Or is there another possiblity?
Thanks for your great help.
Yves
Message 7 of 17
(3,877 Views)
You can have the choice if you modify a bit Dennis' example.
For instance you can put in a list (or ring or dropdown or enum) the names of the progam you launched and when you want to stop one of then, you first select it in the list and then click a button "stop this VI", you then get the appropriate reference to stop the VI.
Is my explication is not clear enough or do you need an example VI ?
Epictetus
Antoine Chalons
Message 8 of 17
(3,874 Views)
Although I think I get it I would appreciate an example. (Just tried it but I must have misunderstood something because it didn't worked.)
Thanks very much
Yves
Message 9 of 17
(3,864 Views)
Here is a quick example, I haven't tested it... hope it works without any change 😉
Epictetus
Antoine Chalons
Message 10 of 17
(3,858 Views)
