opc servers
Hi, i'm having trouble connectiing my NI opc servers to my omron cs1 PLC using fins ethernet. Has anyone done this before?? you got any pointers??
Stu
(3,102 Views)
Hi friend,
Creat channel in opc server.
then select your plc from the list.
set the parameter as given below.
Device Driver: Omron FINS Ethernet
Diagnostics: Disabled
Network Adapter:
Default
Write Optimization:
Write only latest value for all tags
10 writes per read
Port Number: 8000
Then Creat Device into the chennel. To view your data on opc. click on opc client ( hammer symbol in tool bar)
Brijesh
CLAD
Labiew programmer
(3,097 Views)
Hi, done that still no comms, can only think the PLC settings are wrong or the fins comms is set up incorrectly.
Stu
(3,086 Views)
