nyquist graph
hey everyone,
how can i make more clear Nyquist diagram?
On my graph program connects all the points. I'd like to have a nice circle. nyquist.JPG
If someone knew?
Marek
(3,532 Views)
Accepted by gfds
Click on that trace close to the Plot 0 on the top right corner of the graph and choose Interpolation, then choose an option without interpolation.
You can also configure many other options of your trace there.
Hope this helps,
Paulo
(3,527 Views)
Get the theta (Phase) of your complex numbers and sort it. To do so, you can cluster theta, complex number in a for loop, use the sort 1D array function and unbundle the complex numbers again in a for loop.
Felix
(3,523 Views)
Thanks Paulo.
This is whot I wonted.
Marek
(3,503 Views)
Felix,
Thanks you also for your reply.
Marek
(3,501 Views)
