numeric text box:Change colour after calculation
How do you change the colour of a numeric text depending on the result of an arithmetic calculation ?
I assume its something to do with property node....Can some add to my basic program to do the following:
See attached picture of current basic program.I am using Ver 8.0.
If the output of x+y >5 then i want the output text box to turn Red.
If the output of x+y>5 then i want the output text box to turn Green.
The default colour should be white.
               labtech5555
(2,704 Views)
The comparison can be done using a case structure (you can feed the numeric into the selector and use some syntax, available in the help, to select ranges).
The coloring can be using a property node. Right click on the control or the terminal and select Create>>Property Node. Then select the Numeric Text>>Text Colors>>BG Color property.
___________________
Try to take over the world!
(2,698 Views)
OK, this makes no sense at all. If x+y > 5 it cannot be red and green at the same time.
Here's some simple code that would make the background of the indicator red if the result is >5 and green otherwise.
Maybe you can modify it for waht you really want. (I cannot tell.) 😉
(2,677 Views)
Ah, those pesky details...
___________________
(2,662 Views)
