numeric properties error
Hello, There is an issue that I've encountered in LV 8.6.1 where all of my system numeric controls share their properties. For example, I place Numeric on the front panel of a VI, then right click and select "Data Entry...". Then I modify the data entry limits to be 0-100. If I place Numeric 2 on the front panel and open its Data Entry limits they are the same as the first Numeric.
I don't know if this is a bug or if I just have a corrupt installation of Labview. Although, this has been repeatable on multiple systems with LabVIEW 8.6.1 installed on it. I will attempt to repair/reinstall my installation of LabVIEW and post back. However, I think that this is pointing to a bug with 8.6.1.
Tim Sileo
Tim Sileo | RF Apps Engineer | NI/Emerson | ADG Business Unit
(3,812 Views)
Yep definitely a bug. Repairing my LabVIEW installation did nothing to fix this issue.
(3,803 Views)
Accepted by topic author TimS.
This bug has been reported here.
(3,791 Views)
(3,788 Views)
Thanks to both of you, I must have missed that thread on my initial search. I've installed the patch and everything works as expected now.
(3,783 Views)
