numbering system , to .
Hello everyone,
i have a problem with the setting of the numbering format. In germany, the value 1.5 is written as 1,5. So my labview program recognise 1,5 instead of 1.5 I want to set in to the normal american numbering system instead of the german system.
Where can i change the setting  for it ?
Thank You
(3,358 Views)
Depends on what you mean by "recognize". Is this reading from a file? Is this for a front panel control? Is this for writing out to a file? Is this for a built application?
See, for example
How do I Convert a String with a Floating Point Number That Uses a Comma for the Decimal Point into...
How Can I Localize My Executable So That the Decimal Separator Is the Same on European Computers?
as well as all the other links from this search.
(3,352 Views)
When you use the Scan from string function, start the format string with '%.;' this will set the decimal sign to a point.
Ton
My LabVIEW Ideas
(3,328 Views)
Accepted by topic author yehchia
There's also a an option "Use localized decimal point" under Tools -> Options -> Front Panel . It's a global setting that affects the whole development environment and you'll have to restart LV after changing it.
(3,313 Views)
All good answers above.
As smercurio mentionned, what is meant by "recognize"?  In other words, how is this localization used?  The answer to that will select the appropriate solution.
(3,300 Views)
Thank you
(3,281 Views)
