number to decimal string
Do you know if there is another fonction, similar to the image below, which doesn't convert the float value ?
Peter.
Labview 2010
Message 1 of 12
(8,105 Views)
Doesn't convert???. Are you talking about the "Number to Fractional string"? Your query is not clear.
Message 2 of 12
(8,102 Views)
In fact, when I use this fonction to save my data in a lvm file, this fonction converts, for example, 2.7 to 3.
And what I want is to save the data without convertion.
here is my program
Regards
Peter.
Labview 2010
Message 3 of 12
(8,091 Views)
Accepted by topic author Peter Saraiva
The function you are looking for is "Number to Fractional string" as already suggested.
The one you use is for integers, that's why 2.7 is converted to 3.
Marco
Message 4 of 12
(8,084 Views)
Use this.
Bijay
Message 5 of 12
(8,081 Views)
You appear to be using the wrong function:
http://digital.ni.com/public.nsf/allkb/6FC8B91AD740FCC88625723D005FEA61
Message 6 of 12
(8,079 Views)
thanks for your help;
So now the other problem is quiet the same,when I read the data in my file, the fonction that I use converts the data to an integer.
Peter.
Labview 2010
Message 7 of 12
(8,073 Views)
Use "Fract/exp string to number" function.Smiley Happy
Bijay
Message 8 of 12
(8,071 Views)
This is what I use, I surrounded it on my last image.
Maybe that the parameters are not good ?
Peter.
Labview 2010
Message 9 of 12
(8,067 Views)
Ohh... remove that integer constant from default terminal of the function.
Sorry, i didn't notice that.
Bijay
Message 10 of 12
(8,065 Views)
