not receiving all data across tcp/ip port
i am trying to transfer data across a tcp/ip port.  the data is in binary and is reliable when small amounts of data is passed.  it starts to fail when i try to transfer around 10000 bits and it is random(sometimes i get more or lest data when requesting the same amount).  any advice on what to do.  i attached the vi so you could see the code but it won't run unless you edit the ip and port to work with your settings.
thanks
(2,833 Views)
Here is a Developer Zone article that explains more about TCP communication. Is your code set up similar to these examples? Are you able to run a TCP example from the LabVIEW Example Finder?
Amanda Howard
Americas Services and Support Recruiting Manager
(2,799 Views)
i think i figued it out. i use the tcp communicator active example for a starting point and edited piece by piece to get it to work.
one thing i would like to mention is if you get error 62(serial overflow).  you may be sending data multiple times and not exiting the while loops in the example.
thanks.
(2,783 Views)
Thanks for posting back with comments about your resolution. This helps other members of the forum community. Have a great day!
Amanda Howard
(2,762 Views)
