not getting an output signal
If your device allows it, yes, change the range to allow negative value outputs as well.
Cheers
Message 11 of 21
(2,758 Views)
Ok so now I made some adjustments. This time I get this error.
Possible reason(s):
Not enough samples were written to satisfy the initial data transfer request condition.
To successfully start a generation, increase the number of samples initially written to the buffer before starting. Alternatively, decrease the number of samples required to start by changing the data transfer request condition.
End of Data Sample Number: 0
Minimum Value: 0
Task Name: _unnamedTask<8>
Could you help me understand why I get this one.
Message 12 of 21
(2,748 Views)
Make sure you're generating the waveform correctly.
Cheers
Message 13 of 21
(2,733 Views)
I see in reg compute waveform it is skipping the for loop i have hooked up to the main vi. Do you know why that is? nevermind i figured it out.
Message 14 of 21
(2,726 Views)
All of your values are default zero so I don't know what values you're using. Probe the wires to see what values are being written. If you write a value of zero to N, the For loop will not run...
Use the debugging tools, Reggie.
The real question is, why are you generating a sine wave this way?? There are so many better ways of creating a sine wave.
Look here.
Cheers
Message 15 of 21
(2,721 Views)
sorry that was very stupid of me. I did leave out a number.  I guess the last question is how do i get it to produce multiple square waves and not just one.
Message 16 of 21
(2,713 Views)
What do you mean multiple square waves? Different waves for each channel? Run the code with different settings in a For loop for this.
Have you ever gone through th LabVIEW tutorials?
Cheers
Message 17 of 21
(2,709 Views)
Are you seeing more that one channel because i only have one hooked up to the daq. But i guess what i am trying to say is that I am suppose to output 5 square waves but I am only getting one. Do I need to put in a wait time? or wait until done vi.
Message 18 of 21
(2,705 Views)
5 pulses? Your plot shows multiple on the graph there, so you should be outputing multiple. I can't tell from your graph whether or not the gap between the pulses is a jump from high to low, or just a quick drop to low for a split second. Maybe you're just not seeing it because it's too fast.
Cheers
Message 19 of 21
(2,699 Views)
How's this working out Reggie?
Cheers
Message 20 of 21
(2,668 Views)
